Disables the router alert IP option in outgoing OSPF control packets.
This command has no keywords or arguments.
Disabled.
Not applicable.
The following command disables the OSPF router alert IP option:
disable ospf use-ip-router-alert
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
